11-29-2016 04:49 PM - edited 01-05-2022 01:03 AM
My husband wants to sign up as a new user for the 6g 120 day plan. I have the 12g 120 day plan. He uses more data than me and I wonder after I port if I can change plans with him. Thanks for your help.
Service
11-29-2016 05:01 PM
Hi @Bella!
Have your husband's number ported to your account. You will lose your number. This is the only way we, as cutomers, can achieve what you want. Then you can sign up for a new line with new number.
Any other scenario would require a mod's intervention. So, if you want to keep your number, then you have to go through private message to a moderator.
Have your husband sign up with a new line and port his number to PM. Then you and him both send a private message to the same mod stating that you wish to do the switch. I have not heard of anyone doing this in the past. But, this is the only way forward.
The mods are very accommodating and if this is possible, then they will do it for you. If not, then this will cost you your number becasue you will effectively be handing over your account to him and starting a new account for yourself.
