12-08-2022 05:42 PM
How do you change your username in the Public Mobile Community?
12-08-2022 07:59 PM
Yup it is true. Had mine change 1.5 year ago.
12-08-2022 07:35 PM
I HAVE DONE IT TOO....MANUALLY.
12-08-2022 07:08 PM - edited 12-08-2022 07:08 PM
@CountyDownIeUk Yes, I'm certain and a few members have changed their usernames that I'm aware of, luckily I don't remember their original names. Looks like poor old SIMon is wrong, again..
12-08-2022 06:44 PM
@CountyDownIeUk- BKNS27 is quite entirely certain from personal experience.
12-08-2022 06:43 PM
12-08-2022 05:47 PM
Sorry but, you can't do it yourself so you have to get a Customer Support Agent to do it for you.
12-08-2022 05:45 PM - edited 12-08-2022 05:51 PM
@WolverineCaz You'll need to contact customer support via chatbot to have the name changed. Here's a link to chatbot to submit a ticket: https://www.publicmobile.ca/get-help
edit: BTW, luckily once CSA's change your name, then all posts with the name you have now will automatically also change including where the name has been tagged like in this thread.
12-08-2022 05:45 PM
Only a CS_Agent can change your user name.
Just private message them if you are not in a hurry or create a ticket on SIMon Chatbot for a speeder reply.
