NO ESIM FOUND
11-07-2024 02:21 PM
11-07-2024 03:20 PM
HI @nitnai
so, all good after buying a new esim?
yes, support will reimburse. It is said on the help page that esim replacement is free.
11-07-2024 03:18 PM
yes done, they should be adding a credit , Thank you
11-07-2024 03:14 PM
@nitnai If you rebuy esim on the app it will crest you the money at check out no need to message support for refund
11-07-2024 03:07 PM
hi @nitnai
you just need to pay first to get the service working , then ask Support agent to reimburse
Good thing for eSIM is if is free (with reimbursement) for getting replacement esim
11-07-2024 03:05 PM
But i was offered a free esim, why pay
11-07-2024 03:00 PM
hi @nitnai you need to ask support to help. Please message them
at the same time, try login PM app, see if you can login. If so, go to Account page and buy new eSIM there. Thaf would solve the problem without agent help
of course if you can login, message agent is the only way
11-07-2024 02:58 PM
The QR CODE is invalid, cannot use
11-07-2024 02:52 PM
hi @nitnai you can check the welcome email from PM, the eSIM qr code is there and you can scan and install
if you cannot find the QR code, message support for help
11-07-2024 02:51 PM
NO ESIM FOUND
11-07-2024 02:24 PM
hi @nitnai did you use the app to subscribe and got to the last step of the activation which helped you to install the esim?
if so, check the sim card manager screen or Settings -> Cellular and make sure Public Mobile eSIM is there and enabled, or Turn on this sim is on
if not, then ask support for help. please message them here
