My voicemail button no longer works it
Millercrew37
It says voicemail call failed
2 REPLIES 2
Manwiththe
Try re-insert your sim and restart your phone so your phone re connects to the phone carrier!
If you dont get it fixed, and need to check voicmail, call your number on a different phone (works with text/calling app on your own phone too) and press * when you get your voicemail, and then if you have a code enter it if not set one up to listen to your voicemail! This is especially handy if theres times that you cant pay your bill in time but need to get your messages!
@Millercrew37   you can program it back,
use one of the number from this list
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
but first, you should check if you can reach your VM or maybe just VM system problem and not the voicemail button
Call one of those number and see if you can access voicemail from your phone first.  If that does not work, try to call from another line
