08-20-2018 12:59 PM - edited 01-05-2022 12:35 AM
Recently my contacts are complaining that they are receiving multiple duplicate of my text messages to them. I have a OnePlus Andriod phone and I use Textra app for my SMS. Any thought of why this would be happening?
08-20-2018 03:48 PM
Thanks everyone. I will give the Google sms app a try and see if this resolves the issue.
08-20-2018 03:40 PM
@srlawren, I too took advantage of the new Messages app, but miss the ability to increase the font size in-App.
However, I can get around this most times now as this app can be sent to the web browser on my PC or macbookAir.
08-20-2018 03:07 PM
I've had this happen occasionally in the past but it usually goes away on its own. You could try rebooting (if you haven't yet), or swtiching maybe to a different texting app at least long enough to see if that makes any difference. Google's own Android Messages app is completely free and pretty decent these days https://play.google.com/store/apps/details?id=com.google.android.apps.messaging. I switched from Textra back to this about 6 months ago when someone pointed out Textra's privacy policy to me. At that point I decided it wasn't worth the nicer theming and such. I do miss delayed send though! I wish every messaging app I use had it.
08-20-2018 01:10 PM
@stonechucker wrote:The only time I had an issue like that was back in my Rogers days, using Rogers1Number. I would send an SMS from my iPad or my computer, and it was sending duplicates.
Rogers blamed Telus, and Telus blamed Rogers. Most likely a carrier issue, rather than your software.
I would be inclined to think the problem is the app.
08-20-2018 01:07 PM
