3 hours ago
My sister lost her phone and can't login. How can she submit a ticket to suspend her account?
39m ago
The link only works if she can login her public mobile account otherwise no field and submit button shown
an hour ago
@TT2024 wrote:If she can't access her public mobile account and email account, is there any other way that can be done to submit a request to suspend her phone so that no one can access her phone and account?
yes, as said already, she can message PM here:
an hour ago
3 hours ago
@TT2024 wrote:I submitted a ticket for her to CS_Agent but no return info. I am not sure if the submission went thru.
Going into your Community private messaging outbox. For any submitted ticket, there is a messages there that will show a ticket number.
3 hours ago
@TT2024 depending how busy the agents are it can take a few hours to hear back. Just keep an eye out for a reply back by checking your inbox (envelop icon in the top right corner).
3 hours ago
3 hours ago
@TT2024 wrote:She can't access her email as well.
In that case, use the chat symbol on the lower right corner of the web page to initiate a support ticket. Eventually she will need to access her account.
3 hours ago
@TT2024 if she can't access her email on file she will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
3 hours ago
3 hours ago
3 hours ago
she can try to click Resend code and check if email is an option,
if not, she would have to ask PM to help. Message them
And one more ways is to call 1-855-4PUBLIC and disable Autopay there, but only if you know the 4 digits PIN
3 hours ago
@TT2024 , she should still be able to login. The 2FA code can be sent to email, simply request the code to be resent and options will be available to send to email.
3 hours ago - last edited 3 hours ago
@TT2024 she should login to her account through a web browser, if it requests to enter the 6-digit code she should be able to click a link that says "Didn't get code", and then she can have it code sent by email. Once in her account she should be able to remove autopay or pause her subscription:
https://www.publicmobile.ca/en/on/get-help/articles/pause-your-subscription
