My ported number is stuck.
Paul141
I can call and use data texts ext... however I cannot receive calls at all. I was told this was an issue with porting my number VIA a text from public mobile. However I need a moderator to help me and fix this issue for me asap!
2 REPLIES 2
@Paul141  No worry there a number for live support to fix . Will send you private message
@Paul141
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card, and only outgoing calls, wok  then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
