03-17-2021 12:41 PM - edited 01-06-2022 02:19 AM
Hello sir I have forgotten my pin number.For change of credit card particulars u have blocked my account.I need to send u the renewed credit card details to make auto pay active again. My cell no:1 xxx xxx xxxx.pls respond
Edit by Dunkman: removed personal information
03-17-2021 01:38 PM
@Dunkman thanks for the help. 😊
03-17-2021 01:05 PM
Here’s when and how to contact the Moderator Team:
03-17-2021 12:48 PM - edited 03-17-2021 12:49 PM
@Shawkatkhan52 : Do you mean your self-serve login password? Or the 4 digit PIN? Did you try the Forgot your password? link?
Are your services currently suspended?
Edit: You can't do anything with the card in 611. Only toggle autopay.
03-17-2021 12:48 PM - edited 03-17-2021 01:05 PM
@Shawkatkhan52 wrote:Hello sir I have forgotten my pin number.For change of credit card particulars u have blocked my account.I need to send u the renewed credit card details to make auto pay active again. My cell no:X XXX XXX XXXX.pls respond
@Shawkatkhan52 please click the 3 dots on the top right corner of your post and deleted your phone number. These are public forums so don't post any personal info.
edited reply
If you activated in-store, your PIN# was sent to you by text. It would be the 4-digit number nothing else.
If you need to contact the moderators to update your registered credit card, there are two ways to contact the Moderator_Team
It may take up to 48 hrs (hopefully less) to receive a reply from the moderators. Keep checking the envelope icon on top right for a number to pop up. That would be the moderator’s reply.
I hope this helps
RosieR
@computergeek541 please help
