12-09-2020 02:03 PM - edited 01-05-2022 04:25 PM
from existing same issue. it seems my SIM card internal account in your server side is deleted.
Please recover it now and give me 2 mothes free. I missed many calls due to your fautl
12-09-2020 10:42 PM - edited 12-09-2020 10:52 PM
@w20565 wrote:can you tell me what is the next step ?
As posted by others. Log into self service and put your phone in lost/stolen mode and change the passwords. Go secure your financials and change passwords if necessary.
Then contact moderators and tell the you were sim jacked. Use this link to private message them.
12-09-2020 10:10 PM
12-09-2020 03:03 PM
it sounds moderators didn't understand what happened
12-09-2020 03:02 PM
sim card number changed.
12-09-2020 02:41 PM
I guess you tried re-sit the SIM (turn off.. take SIM out.. wait a min before putting them back).. but it works for me last time.
Anyway is to go to a store (Walmart) , pay $5 and get a new SIM.. it does happen sometime SIM just broke for no reason
12-09-2020 02:24 PM
@w20565 wrote:it is bad. the last 4 are different.
Then you have work to do.
Then come back here and get the moderators to reinstate your original SIM and then you can use the same lost/stolen function to Resume service. Or buy a new SIM.
12-09-2020 02:23 PM
12-09-2020 02:20 PM
12-09-2020 02:12 PM - edited 12-09-2020 02:14 PM
@w20565 wrote:and , other SIM card can work on my device when I test it. So it is not my phone device issue. it is either the sim card , or the network, or your background service software issue.
Hi @w20565 please log in your self serve account, click the Plans & Add-ons, then click Sim Card Change. Does the last 4-digit of your sim card you see here the same as the last 4-digit of your actual sim card? If yes, that's good.
If not, as already suggested above, you have probably been SIM jacked. Change your password and name on the account. Immediately place your phone on lost/ stolen. Change email, bank, credit card passwords that may be at risk. Contact the relevant places.
Two ways to contact the moderators:
It may take up to 48 hrs (hopefully less) to receive a reply from the moderators. Keep checking the envelope icon on top right for a number to pop up. That would be the moderator’s reply.
12-09-2020 02:09 PM - edited 12-09-2020 02:10 PM
Or you've been SIM-jacked. Can you still log in? If so then go into the Change SIM screen and take note of the 4 digits of the registered SIM card. Then compare that to the actual one in your phone. Are they the same?
If not then use the Lost/stolen function to Suspend your account and then change the password and then run around to all your financial logins and make sure you haven't lost anything.
Edit: or simply as above 🙂
12-09-2020 02:08 PM - edited 12-09-2020 02:11 PM
@w20565...
log into your account to see if it's expired. When was your most recent renewal date ? Did you have a credit card set to Autopay and it failed ?
Top of this page, click Get Help / Chat with Simon to start process of moderator assistance.
12-09-2020 02:07 PM
please help to address it ASAP. it blocks my life.
12-09-2020 02:06 PM
12-09-2020 02:03 PM
I am in ON.
