My phone is not working!!!!! It will not receive texts or calls
Mrshilltop
hycm53
@Mrshilltop Is your phone unlocked? Is your phone compatible with PM? Check your phone is compatible with PM here:
https://willmyphonework.net/
https://www.kimovil.com/en/frequency-checker/CA
https://www.publicmobile.ca/en/bc/get-started
ChuckYeah
Try sending a text to your own number. See what happens .
RossN
@Mrshilltop hi did you just sign up? did you port a number if so from where?
