07-20-2019 09:34 AM - edited 01-05-2022 05:59 AM
I activated my phone yesterday but it is not connected to the internet. Any suggestions?
07-21-2019 07:31 PM
Thanks, I guess that's what I'll have to do.
07-21-2019 07:29 PM
Done. Still no signal.
07-21-2019 04:09 PM - edited 07-21-2019 04:10 PM
@sjbirdWhen you say no Signal.. does Public Mobile display at your phone in the top left hand corner? (usually for Android and iOS phones). If Public Mobile is no where to be found and there is no bar.. it sounds like a provisioning error and only moderators can fix that.. expect up to 48 hours wait.. so go out and enjoy the weekend.
07-21-2019 03:47 PM
07-21-2019 11:37 AM - edited 07-21-2019 11:41 AM
@sjbird Login to your self-serve accountand look on the Overview page to see if you have data available to use. If yes, go back to APN settings and match it with the one found here: https://yourmobile.ca/apn-settings/
07-21-2019 11:29 AM
Sorry to say, I've powered down and then back up several times. No improvement. And there is no lock from my previous provider. I put in a query to Public Mobile itself Friday evening. No reply so far.
07-20-2019 11:58 AM
@sjbird You may try powering off your phone, then turning it back on. And, if that option does not work, you may need to have your phone unlocked by the last service provider/carrier.
07-20-2019 10:45 AM
@sjbird wrote:I activated my phone yesterday but it is not connected to the internet. Any suggestions?
What make/model/submodel is the phone?
What OS and version is it running?
Usually network settings automagically get populated but:
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
07-20-2019 10:37 AM
First make sure the data is turned on for your phone, then try turning your phone off then on again, and if that still don't work then search APN in the above serch box to confirm all your APN settings are correct - then if all that don't work, you'll have to contact the Moderator Team via private message to fix this.
07-20-2019 09:39 AM
So does calls and text work? Just not internet? What kind of phone is it? The apn may need to be configured for the internet
