My phone is 2G/3G network.
11-14-2016 10:34 PM - edited 01-04-2022 06:19 PM
11-16-2016 08:14 PM
Thanks
11-15-2016 06:00 AM
Hi,
4G LTE is a hardware capability in the phone. If you are sure your phone is 2G/3G , then it is not compatible, and does not work with 4G LTE bands.
11-14-2016 10:52 PM
Also, don't worry if your phone only supports 3G.
PM's 3G network is fantastic, and the difference between 3G and LTE is barely noticeable in my experience. I know because I originally had LTE disabled on my phone before switching.
I think the only time you would notice is when doing big downloads or uploads.
PM's 3G network is like a day and night difference between a major competitor's 3G-only network. I did side-by-side tests.
11-14-2016 10:38 PM
Use this site to check the specific make and model of phone against the PM network.
I use a phone that only had 3G and it works fine. It connects at 3G speeds.
11-14-2016 10:37 PM - edited 11-14-2016 10:38 PM
