11-18-2019 02:07 PM - edited 01-05-2022 08:02 AM
Hi, My old phone has died, Need to transfer my number to a new phone, How do I go about it?
Phones
11-18-2019 05:24 PM
It's quite simple, all you have to do is take the sim out of your old phone and put it into your new phone, the number and everything will remain the same.
11-18-2019 03:26 PM
If your new phone uses bigger sim than your old phone you may need a sim adapter.
I have a spare one from nano to micro.
Where about are you located?
11-18-2019 03:01 PM
11-18-2019 02:39 PM
Transfer sim from old to new phone and adjust settings.
11-18-2019 02:23 PM
Don’t forget you probably have a Tri Sim. Use as is or push out the size you need. Also I hope you kept the original pieces just in case you have to make it bigger.
11-18-2019 02:08 PM
Remove your sim card from your old phone and put it in your new one. If you use data then you may need to setup APN settings.
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
