08-20-2015 07:54 PM - edited 01-04-2022 01:55 PM
I bought a new cellphone in China, it can be used in the network of TDD-LTE:2600(B38)/1900/2400/2600(B41); FDD-LTE:1800/2100/2600; TD-SCDMA:1900/2010;WCDMA :900/2100; GSM 900/1800/1900, but i can not use my Public Mobile SIM card, I don't know my SIM card is not a LTE SIM card or I must change my plan?
09-04-2015 07:12 PM
Yep, That sounds correct
09-04-2015 07:07 PM
Hi for the phone model, choose the one with WCDMA 850/1900, which is quite common for non-China model like Samsung, LG, Motorola etc. For LTE, choose the one with 1700/2100. Some this year model may have this band. However, the China branded model you have mentioned will NOT have the properly LTE band (some may have the WCDMA 1900 like Xiaomi). 2G (GSM) is not available in Public Mobile even though you may willing to be slower.
08-20-2015 08:34 PM
@makkahn28 wrote:Moto G, Example, has like 6 different Sub-Models
Some had ONLY 2G GSM, Some 2G, 3G, Some 3G, 4G, or all the above
That's the tricky part
That's true.
I just wanted to correct you where you said don't buy a Phone in Europe or Asia. That's all.
You know I only post Facts, if I am unsure I don't post or if necessary I will say Probably, maybe etc. But mostly Facts.
08-20-2015 08:31 PM
08-20-2015 08:28 PM
Easier said than done.
If a Phone has 6 Sub-Models, Like Moto G, example, you would have to know the Exact Brand, Model, Sub-Model, then Do a IMEI Test, or using that www.willmyphonework.com
Just to figure out if Handset will work.
08-20-2015 08:23 PM
@makkahn28 wrote:Well, If that's the case, Wondering how can they determine which is compatible or NOT
Easy look at the Frequency used by Bellus & then look at Frequencies on the Phone you are buying.
08-20-2015 08:21 PM
08-20-2015 08:19 PM
@makkahn28 wrote:@muyusy, Simple, Handset is NOT Compatible.
Buyer BEWARE
If bringing a Phone over, Recommend buying in Canada/US
Asian and/ or European phones have DIFFERENT Frequency spectrums, so this can be a big issue
Is it too late to return Phone Back?
FYI:
Most current phones from Asia & Europe have HSPA/HSPA+ & some LTE frequencies for the North American wireless market. However most Phones intended for the Japan & China 'DO NOT'
08-20-2015 08:14 PM
@muyusy wrote:I bought a new cellphone in China, it can be used in the network of TDD-LTE:2600(B38)/1900/2400/2600(B41); FDD-LTE:1800/2100/2600; TD-SCDMA:1900/2010;WCDMA :900/2100; GSM 900/1800/1900, but i can not use my Public Mobile SIM card, I don't know my SIM card is not a LTE SIM card or I must change my plan?
Your Phone has only one Frequency for Canada which is 2600Mhz LTE. However this Frequency is only available to Bell. Even though Bell &Telus are really one network but that Frequency is currently not in the shared Network agreement between the two.
Also lets just assume it was available on Telus even then your Phone will only have LTE data where that Frequency is deployed & you will not have had voice calling because currently Voice calling is not available over LTE.
08-20-2015 08:09 PM
Buyer BEWARE
08-20-2015 08:05 PM - edited 08-20-2015 08:07 PM
As posted elsewhere the PM network requirements are the following:
Telus/Koodo/Public Mobile frequency are :
3G UMTS/HSDPA = (850MHz / 1900MHz) aka Bands 5/2
4G LTE Band 4 = (2100MHz / 1700MHz) aka paired together Band 4
4G LTE-Advanced = 700MHz (LTE-A not yet launched by Telus/Bell) aka Band 17
Do you need some ideas on where to purchase a compatible phone?
Have you registered the SIM and created an account? It will not function, otherwise,
