My data plan is not working
Fred5454
Hi, for the past few days, my data plan is not working and I have no access to internet outside of wifi. Thanks for your help in resolving this
Fred
@Fred5454 -
Are you able to use your calling and texting services working okay?
If you are showing the data line in your overview section in your self serve account (as @dust2dust and @BKNS27 ) posted, try below troubleshooting:
  • restarting your phone
  • remove and reinsert your sim
  • toggle into/out of airplane mode
  • reset device's network settings
  • try your SIM into another phone to see if data works
Where are you located ...perhaps there's an on-going outage issue in that area.
Fred5454
It shows I should still have data. Not sure why it’s not working
@Fred5454
What plan are you on?
You might have used up all your data for this month.
You will need to login to your account (on you phone or a computer through wifi) and check under My Data & Add-ons. If it is not listed then you used it all up.
You can view your data under View My Usage.
dust2dust
Have you checked your account for data left? If you know your 4 digit account pin you can dial 611 to get the amount left if any. But also log into your account and check under my data & add-ons.
