My data is not working
Kodavidcho
It says I have 5G and LTE, but my data is not working nothing will load and my messages do not work. Please help.
check any active outage in your area
https://www.telus.com/en/bc/outages
or you can test your sim card with another phone if you have a physical sim
and of course, you can ask PM to check your account.   Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
Kodavidcho
Everything is working, but my data. It was just working last night. For some reason it has stopped working today. I tried rebooting resetting my phone nothing has worked.
slusagm
if you are a new subscriber, make sure you removed the old sim card and esim.  Also, check to make sure Public Mobile sim is the only one enabled and set as Primary.  You can then Reboot phone and Reset network settings
after that, check data again, and check of voice calls and text are both working, both incoming and outgoing text are working
