10-16-2021 02:52 PM - edited 01-06-2022 03:33 AM
My online profile is showing $35 for the next renewal however my plan is $25 a month
10-16-2021 06:44 PM
@redmoun wrote:My billing date is October 17th , my plan was $25 dolallars , i ve upgraded to $35 plan 3 days later i ve changed the plan back to $25 and i got a message conirmation tahn the changes will take effect next october 17the However the system keep showing $35 as a amount due .
Maybe system did not 'like' how fast you flip flopped your plan. From 25 to 35 then back to 25... Hmmm.
10-16-2021 04:12 PM
@redmoun I understand that you changed to $35 but you also changed it back to $25 after. I think it should show $25 plan.
best way is to contact CSA just in case.
did you try to Change to $25 plan again? If you successfully change it back to the $25 plan earlier, it shouldn't let you. if you are able to change it, then it is still good, you change it back before it is too late
10-16-2021 04:07 PM
normally I have seen the My Account page showing different amount when the plans have been changed.
My suggestion at this point will be have autopay setup for just in case.
When renewed, it'll be all fixed, if not, contact CSA as suggested.
10-16-2021 03:48 PM
The self serve account shows the cost of renewal based on the current plan cost not the plan that you will be switching to. It is rather confusing but as long as you have the $25 plan selected for the next renewal, the cost will be $25+tax.
10-16-2021 03:22 PM
10-16-2021 03:13 PM
If your plan is scheduled to the $25, don't worry about it. It will be reflected upon your renewal and you will be charged the $25 less any rewards/available funds.
10-16-2021 03:11 PM
Thank you so much for your Help , i just sent a message to CS agent
10-16-2021 03:06 PM
you need to Contact Customer Support Agent by CS_Agent , and Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck...
10-16-2021 03:03 PM
10-16-2021 02:56 PM
Did you make a plan change for next renewal ?
Can you post a screenshot of your account masking any personal information ?
10-16-2021 02:55 PM - edited 10-16-2021 02:55 PM
