02-26-2021 09:45 PM - edited 01-06-2022 02:12 AM
02-28-2021 01:04 PM - edited 02-28-2021 01:09 PM
@Yoanchai : Check your phone for texts from 611. The first entry might be your PIN. It could also be stored on the SIM itself.
You can also use the Instant Top-up method at a few stores.
Did you activate yourself online? Or in a store? If yourself then you can also make payments in the self-serve. If from a store then did you create a self-serve account?
Edit: Oh...and vouchers from many stores or online. You don't need a PIN for those.
02-28-2021 12:58 PM
02-26-2021 11:00 PM - edited 02-26-2021 11:01 PM
You do not need a PIN number if you're using *611 with your phone to make a payment via a payment voucher.
Can buy one at many locations:
02-26-2021 10:45 PM - edited 02-26-2021 10:49 PM
your account is suspended, but you should still be able to make payment..on Self-Serve with Credit card, then reactivate the account..
did you mean you can't logon Self-Serve at all??
02-26-2021 10:40 PM
It may be easier and faster to buy a voucher and load it onto your account via 611. Simply dial 611 from your phone. Press ( 1 ) then ( 1 ) again and enter the 12 digit code.
02-26-2021 09:50 PM
Hi @Ozie ,
Can you make a payment in your SELF SERVE account: https://selfserve.publicmobile.ca/
Only way to reset set your PIN is through the Moderators.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Faster Method - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower Method - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
