My Rewards
Toxin
If I change plans would my rewards follow my new plan? (I.e. Loyalty, refer a friend, etc.)
1 REPLY 1
@Toxin  Yes absolutely you will keep old rewards  i can confirm . I just switched plans too and kept my rewards check it out
Just make sure to change plan for next renewal and not immediately . This way you won’t lose money in your current cycle
