12-01-2019 06:08 PM - edited 01-05-2022 08:15 AM
I have purchased a new phone which is not allowing me to access the internet/email from outside my home. I took it back to where I purchased it and was told there is nothing wrong with my phone but with my phone plan. What do I have to do with Public Mobile to enable this feature? Thank you.
12-01-2019 07:28 PM
@JKFollett check to make sure your data is enabled and your APN settings are correct for public mobile
12-01-2019 07:27 PM
How do I check that?
12-01-2019 07:27 PM
This plan includes: - 4.5GB at 3G Speed
My phone is an Asus
12-01-2019 07:23 PM
Thanks, I will give it a try.
12-01-2019 07:22 PM
Yes
12-01-2019 06:41 PM
Also, Make sure to check the features available in your plan. You should have internet data bundle availble to use the service properly out side home
12-01-2019 06:19 PM
Hi @JKFollett
Which plan do you have?
Is it an lg phone? They usually have to be set up manually to work properly?
12-01-2019 06:11 PM - edited 12-01-2019 06:12 PM
@JKFollett wrote:I have purchased a new phone which is not allowing me to access the internet/email from outside my home. I took it back to where I purchased it and was told there is nothing wrong with my phone but with my phone plan. What do I have to do with Public Mobile to enable this feature? Thank you.
In many cases, the APN settings haven't been set correcly when mobile data doesn't work.
Try the following as a starting point: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
12-01-2019 06:09 PM
@JKFollett do you have data on your plan?
