04-16-2022 12:10 PM
04-16-2022 01:20 PM
This is the route I would go, you are less than a week away, might as well maximize value and stretch your dollar.
04-16-2022 12:20 PM
Yes, you can change your plan NOW. You will be charged immediately.
04-16-2022 12:17 PM
Since it's only a few days, if you are out of data you could buy data add-ons. If you are out of 100 minutes you could buy the $5 500 minutes. These add-ons rollover on your account without another charge until all used.
04-16-2022 12:13 PM - edited 04-16-2022 12:14 PM
@Taurock do you need to renew now because you used up the data or minute and you need to start a new cycle now?
If that is the case, then you will have to open a ticket with PM Support for early renewal, I suggest you to load enough fund first. Then once PM support validated your identity, they can proceed using the fund in your My Account
To open ticket with PM:
1. If you have access to My account: Click on the bubble on the lower right or https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
04-16-2022 12:13 PM
If you want to renew your plan earlier, you will need to contact customer service agent. You will lose whatever is remaining in your present plan. PM does not pro-rate plans.
You can change to a different plans immediately yourself via your self service account.
04-16-2022 12:11 PM - edited 04-16-2022 12:13 PM
In order to update your plan early (without CHANGING plans), you need a Customer Support Agent to do that. Recommend doing on NEXT RENEWAL date.
Here’s the process for changing plans, first login to Self Serve to this screen:
Then, click Change Plan:
Then select desired Plan:
Then choose Change on Next Renewal Date:
