Multi- Accounts need assigning
1mike1
Hi i have my email and phone number BUT it now will not send me a forgotten password link - I have 3 accounts and this is the last one i need to recover to renew my subscription Thanks 🙂
1mike1
Thanks for the links much appreciated
hi @1mike1
yes, you should have 3 separate to login the 3 different accounts, you can get PM support agent to help.  Submit  ticket by direct message:
slusagm
you will need PM to help to sort them out
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
And for renewal, if you don't want to wait, get a voucher from Shoppers Drug mart and load the voucher
