09-06-2023
12:30 PM
09-06-2023
03:28 PM
computergeek541
I have a number that I received when in Kingston ON. I have moved to Ottawa ON, within the same area code. But my local calls now show up as long distance (from Kingston to Ottawa). Is it possible to keep the same number but have the number now based in Ottawa?
09-06-2023 12:38 PM
I appreciate your insight. There seems to be a consensus emerging ...
09-06-2023 12:36 PM
Thanks for your reply.
09-06-2023 12:34 PM
I would have to say no. The prefix is set for Kingston. Granted the area codes may be the same, I say it's set on the prefix itself.
09-06-2023 12:34 PM
@AJRJ No you would have to pick a new number from Ottawa . But even if it shows long distance you shouldn’t be charged assuming you’re on a Canada wide plan .
