09-10-2017 07:32 PM - edited 01-05-2022 03:13 AM
Does anyone know if it's possible to have a roaming plan on the US with a deactivated Canadian account? As in, if I purchase and start a US roaming plan before my plan expires in Canada, will I still have service in the US until the roaming plan expires?
09-11-2017 07:14 AM
Have a look at H2O Wireless as well. They are another MVNO, but on AT&T's network. Very reasonable LTE plans.
You can buy SIM cards on eBay for cheap and activate here before you go.
09-10-2017 10:05 PM
Or you can get this:
MOBILE FOR LESS
09-10-2017 09:40 PM - edited 09-10-2017 09:41 PM
09-10-2017 09:01 PM
You might be over thinking things.
When are you moving to the USA and when does your PM plan expire?
If you pm number is active while in US, just buy the US add-ons.
Forwarding to fongo will not work if you PM plan is expired.
Also are you on one of the old promo plans. I could be interested in taking it over.
09-10-2017 08:43 PM
Yeah I hadn't heard of fongo until now but I'm looking into it! Thanks for the suggestion!
09-10-2017 08:40 PM
While you are waiting for the sim from mint, why don't you get fongo in the meantime, don't port your PM number to fongo but just forward your PM number to fongo, so while you are in U.S. , you can get your calls until you switch to mint.
09-10-2017 08:34 PM
Thanks for your suggestions guys.
Yeah I'm planning to get a plan when I go there but I'm trying to go with a provider called mint that is similar to public mobile. they need some time to ship me the sim so I want to try and maintain service through public mobile if possible for the 10 days until they ship it to me.
I have a couple of other options such as getting a prepaid plan through T-mobile, for whom mint is an MVNO, but Im just fleshing out my options.
Thanks for your help guys 🙂
09-10-2017 08:33 PM
Plans needs minimum one service. Add-ons will not work if you do not have the base item ie no texting in plan roaming texting g will not work
09-10-2017 08:29 PM
Do you think it would count if my base plan has no talk, no text, and no data? It's still $10 for that plan. If so I could just do that and get the roaming plan I need.
09-10-2017 08:22 PM
09-10-2017 08:19 PM
You could get a fongo number and port your number to fongo. It costs 25$.
09-10-2017 08:10 PM
@navins94, if you let your plan expire your addons will not be active either. Your phone needs to be active and have a base plan attached to it for the addon to work
09-10-2017 07:58 PM
I would say in order to have roaming available, you would need an active base plan, including voice or texting.
09-10-2017 07:33 PM
