06-15-2018 11:20 AM - edited 01-04-2022 06:11 PM
Hi everyone,
I am currently on the 30 dollar plan with cananda wide talk. I just saw that there's a new promotional plan that is 40 dollars and 4GB. I was wondering whether I could move to this plan, keeping all my settings (rewards for example) intact?
Thank you. 🙂
06-15-2018 07:12 PM
It is super annoying when they do that. Especially when someone has already posted something that actually works hours before ![]()
06-15-2018 03:57 PM
@smp99 They should do it for you automatically. J/K . 😄 ![]()
06-15-2018 03:32 PM
@GreatCanadian wrote:@stonechucker, yes, there are a couple of posters here who do nothing only suggest contacting the moderators. They are not doing the OP's nor the moderators any favors!!
GC
Yes. They have figured out how to create a macro and then just go nuts.
06-15-2018 03:00 PM
@Cheetah24, just to boost your confidence, I switched 3 of my family's 4 accounts to this plan today and all rewards stayed intact.
GC
06-15-2018 02:58 PM - edited 06-15-2018 02:59 PM
GC
06-15-2018 02:48 PM
@Anonymous, once again, a totally useless post.
There is no need to contact the moderators to reslove this question.
Please read the post before you supply your answer.
06-15-2018 12:20 PM
Hello
you need send a private message Click here
In your message put it, please include .
- your account number , if you have it , or email address .
- your phone number and 4 digit PIN .
- your name .
- Detailed explanation of specific your Plan change
- them can help you a lot nice team service
Good Luck
06-15-2018 11:36 AM - edited 06-15-2018 11:37 AM
As @jp2 said you can make the change in self serve and you’ll keep all your rewards etc. As it’s a limited time offer I highly recommend setting up a future dated plan change ASAP so that you can lock in the promo price even if your renewal date is after the promo ends. Once you’ve set up a future dated plan change PM can’t take the promo pricing away from you. If you wait to make the change, however, you could miss out.
06-15-2018 11:23 AM - edited 06-15-2018 11:24 AM
Yes you should be able to make a future dated plan change as mentioned in the OP. Then everything will stay the same but the plan will change at your next renewal
