Moto G7 Power
06-15-2019 05:05 PM - edited 01-05-2022 05:24 AM
Hello
I am looking into getting the Moto G7 Power but noticed that it isn’t listed in the list of compatible phones. I was told it could still work... By any chance, does anybody have the Moto G7 Power ??? Thanks
Joining Public
07-29-2019 12:21 PM
@Chou wrote:Honestly, my cellphone knowledge is pretty limited but the description on Amazon said : Moto G7 Power XT1955-2 64GB+4GB RAM LTE Factory Unlocked GSM 5000mAh Battery Smartphone (International Version). Hope this helps !
Thanks, @Chou, the Model number is XT1955-2. These model numbers will make getting information a lot easier once you know you can use them when researching phones and if they will work with the carrier you want to join.
07-29-2019 11:30 AM
07-29-2019 11:08 AM
Can you tell us which specific model it is, as the rest of us are still wondering?
07-29-2019 10:10 AM
Thanks everyone! I did ended up getting a Moto G7 power and it worked just fine.
07-29-2019 06:01 AM
@egg007 wrote:You can use Moto G7 Play. I've checked that:
1) Per gsmarena, Moto G7 Power supports the same bands as Moto G7 Play, and
https://www.gsmarena.com/compare.php3?idPhone1=9527&idPhone2=9532#usa,usa,*
2) Moto G7 Play is available on the PM list for checking phone compatability:
https://www.publicmobile.ca/en/bc/get-started
I hope it helps. Good luck!
Can't make blanket statements about phones models. There can be different versions of any phone model, and some might not work.
07-29-2019 12:26 AM
I use moto g7 regular without problems with PM. Moto are great phones.
07-28-2019 09:39 PM
07-28-2019 09:04 PM
Could you please let me know which one did you choose in the model of phones for Moto G7 power since "Moto G7 power' is not in the list of compatible phones? Moto G7 power is the only one I could find it is close to "Moto G7 power'. Many thanks and waiting online for your reply.
06-17-2019 08:34 PM
That"s the beauty of using Motorola phones in Canada, they work on all the carriers networks with no problem. That's my experience, even if I'll new to PM.
06-17-2019 08:30 PM
It'll work for sure because I'm using mine on PM. Moto G7 powers works with no problems what so ever. You'll love the phone. Good choice.
06-17-2019 08:19 PM
Thanks! I am loving these replies 🙂
06-16-2019 05:02 PM - edited 06-16-2019 05:03 PM
@Chou it'll work just fine. Here are the official specs from Motorola:
https://www.motorola.ca/products/moto-g-power-gen-7
GSM / EDGE 2G: GSM band 2/3/5/8
CDMA BC0/BC1/BC10
3G: WCDMA band 1/2/4/5/8
4G: FDD LTE band 1/2/3/4/5/7/8/12/13/14/17/20/25/26/29/30/66/71
TDD LTE band 38/39/40/41/41 HPUE
It supports every single band for Telus (Public Mobile).
More info here:
06-15-2019 10:10 PM
06-15-2019 05:51 PM
Here are the specs for the Moto G7 Power:
https://www.gsmarena.com/motorola_moto_g7_power-9527.php
It should work with PM
Public Mobile uses the following frequency bands:
- 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
- HSPA: 850 MHz, 1900 MHz (UMTS).
06-15-2019 05:09 PM - edited 06-15-2019 05:11 PM
It will work. Any new phone made for the North American market will work with Public Mobile.
