06-23-2023 05:26 PM - last edited on 06-24-2023 12:26 AM by computergeek541
I've been with public mobile for over a year and I'm constantly switching my subscriptions. Just wondering what you think is the best plan to be on
06-26-2023 02:46 PM
@AliFooFoo Just as you are now . Helping and answering questions . And good things will happen
06-26-2023 02:23 PM
Thank you so much - I just double checked and it actually was $39! My mistake 🙂
How do you earn extra rewards by replying to threads?
06-26-2023 11:46 AM
06-26-2023 11:43 AM
I have been with PM for awhile now and I'm quite happy with their plans. I'm currently on a $39.95/month for 20G data, unlimited texting, Canada wide calling, along with voicemail, caller ID, etc. I suppose it all just depends on how fast a network you want and how much data you are anticipating using.
06-23-2023 05:39 PM
@CW1990 Then best value that way would be the 150GB unlimited data 90 . Pay $165 every 90 days works out to $55 a month
06-23-2023 05:38 PM
@CW1990 wrote:Ok. I should have been more specific. I currently don't have internet at home so I'm using alot of data. I'm just trying to the best package they offer.
@CW1990 - best plan varies from person to person. Sound like you want the most data for your buck, make sense.
I would suggest you check your plans in your My Account frequently (which is sounds like you do if you switch often), and also be on the lookout for any promos that may pop up in My Account or here on the Community or via email or text.
06-23-2023 05:32 PM
@CW1990 best plan depends on you data consumption. Best plan now is the $39-20GB or $45-30 GB
And since data cannot be rolled over , you are doing the right thing to change plan according to you needs.
06-23-2023 05:31 PM
06-23-2023 05:30 PM - edited 06-23-2023 05:32 PM
06-23-2023 05:29 PM
That's at 4G speed, correct?
06-23-2023 05:27 PM - edited 06-23-2023 05:28 PM
@CW1990 For me that’s easy but all preference . But 20GB for $39 is pretty awesome plan I think . And you get to keep your old rewards too
