07-28-2020 04:16 PM - edited 01-05-2022 12:35 PM
Hi,
for the months of may and june, my account was charged 1$ extra for topup without notification, and without any change. Then in july, back to the normal amount. What is that about?
07-28-2020 05:17 PM
@douber Go into your payment history select the appropriate date range and you should be very quickly figure out the why.
07-28-2020 04:58 PM
Another possibly around losing a referral a couple months ago is that you may now have just hit an anniversary date with PM adding an additional $1 loyalty credit putting you back to where you were before losing a referral. And as others have said A possibility is that one of your referrals suspended service for awhile and is now back again.
AE_Collector
07-28-2020 04:57 PM - edited 07-28-2020 05:00 PM
There is no need to contact moderator yet until we find out what is the issue with the referral reward.
You can post a screen shot of your payment history for the last 3 months with your personal info masked out as requested by @totalUser.
One of your referral may be stopped payment for couple of months and now that referral is paying again. If you don't want to post a screen shot of your payment history, you can check the amount of refer-a-friend credit you got on May, June and July renewals. Please update. Thanks
Have a better and better days.
07-28-2020 04:31 PM
@douber wrote:Thank you all for the responses.
When I check in the payment history, all the credits are ok (referrals, auto-payment, and so). The problematic line for the two months is this one :
Automatic Top-Up/Réapprovisionnements auto.
Which has always been 10$ since I became a PM client, and then for may and june, it shows 11$. Then in july, it is back to 10$.
It seems like the automatic top-up got up by 1$, but all the credits are the same and the plan is still 10+5$.
I am not able to send a screenshot at the moment, sorry. I hope this information helps.
Maybe contact the Moderator_Team to look into this via private message using this link.
07-28-2020 04:30 PM
Please contact moderators to look into the matter for you.
Two ways to reach them
1-
2- or via private message at link below
07-28-2020 04:29 PM
07-28-2020 04:23 PM
Log into your self serve account and under "make a payment". Click "view payment history"..
Go through all transactions for last 90 days. You may be able to pinpoint what occured.
Could be you lost a referral or as others said a referral had their account suspended for a period of time.
Or it could be something like the system only applied a credit for a reward after charging you when it normally applies the credit first.
07-28-2020 04:22 PM
@douber if it is 1$, that means most likely your referral was not active and then get back to normal. Do you have referrals?
07-28-2020 04:21 PM
Can you please take a screenshot of your paymenthistory, cropout personal info, that easy we can figure it out.
Every transaction is also named, that should tell you
What is thirty balance?
07-28-2020 04:20 PM
@douber it sounds like one of your friend referrals was suspended for 2 30 day cycles. And was just reactivated. Stay safe.
07-28-2020 04:19 PM - edited 07-28-2020 04:20 PM
@douber hi is it possible you lost a reward/referal or community reward? check in your self serve under rewards
