Moderator help
Ron1539
Please reach out to me regarding billing error.  Can the moderator please message me.
Ron1539
Thanks. Issue was the site  added funds and deducted funds twice while I was thinking it was glitching in a circle. Then I find out the added data is only for 31 days which in the past was roll over data??  Trying to go through Simon and submitting a ticket was horrible, kept erroring out or saying profile error.  Brutal. Thanks for your help.
dust2dust
Nobody will reach out to you. You need to contact them. But maybe we can help you with the problem. What's going on that you think there's a billing error?
Hollister
@Ron1539
You can contact an agent:
You will receive a response from an agent faster using the first option below, which is the preferred method.
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
