@Moderator_Team
sbruce113
How do no find out my pin for services on *611
cavemantoronto
Moderators don't answer tagging so you would still need to do the private message even if you posted here.
@sbruce113
When you activated, Telus (611) texted the PIN info to you "Your new PIN is 1234."
Check your phone to see if you still have this text.
Otherwise, you'll need to contact Moderator_team as stated by @geopublic
@sbruce113 wrote:
ok, I've tried all the pins I know, what do I do if I've forgot it?
@sbruce113  Check your texts from PM just in case it's there. If not, message the moderator. To contact Public Mobile click here. The link  sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
sbruce113
geopublic
@sbruce113  The PIN was created by you during activation.
