Mobile verification texts and/or calls and registrations using my public mobile number
Djhachey1982
So a lot of the time when I try to register for different aps or sites or Why not a lot of the time sites will not recognize my number which is 1 672 999 blank blank blank blank Sometimes I’ll get verification texts when I need them sometimes I won’t sometimes sites or apps will not recognize that it’s a Canadian number therefore it won’t let me register it’s getting pretty frustrating considering that this is all run by Telus and there’s a whole bunch of accounts that I can’t access anymore online because I can’t receive verification text so
I can’t receive verification calls I can’t sometimes register using this number what do I do because it’s getting beyond frustrating thank you in advance for your wise wisdom everybody
Djhachey1982
ok thank you
JL9
This would probably be your best bet, especially if it's relatively new. That way you can avoid those headaches because I don't see that issue changing anytime soon.
@Djhachey1982 area code 672 seems to have problems with receiving calls and texts, common problem not just a PM problem.  If you have not used this phone number for too long, maybe try changing another one with another area code.
You can do so, by going into My Account and click Change Number
HALIMACS
My recommendation,  @Djhachey1982 , is to attempt to utilize email confirmation for those services which cannot easily utilize your public mobile number.
@Djhachey1982
Please do not post pictures such as that containing your information. I have removed it from your message post, but you will still need to remove it from your Community account image gallery.
