4 hours ago
9m ago
@Marl63 wrote:Mobile network not available. Emergency calls only
I would also suggest visiting devciecheck.ca to view the status of your deivce IMEI.
3 hours ago
If you had service so far if could be outage in your area.
Reboot phone, check for major outage here:
4 hours ago
reboot your phone first
if that does not help, check My Account to confirm if your account status is active or suspended. If it shows suspended, make a payment to resume service. (If you cannot receive the 2FA code for login, click Didn't Receive code and Send email to get the code via email instead)
You can also check if your account is active or suspended by calling 1.855.4PUBLIC from another phone and then enter your phone number
if it shows active, try your sim card in another phone. Or you can reach out to PM support for further investigation. Please open ticket with PM support:
