07-13-2021 02:40 PM - edited 01-06-2022 02:47 AM
Hi,
My mobile has no data connection for about 2 months. I checked the setting and found no problem.
Please help by a person, not machine.
Regards
Phones
01-24-2024 10:07 PM
My regular phone data was working but it ran out so I purchased $30 add on but it won't work now.
I have a Samsung android
07-13-2021 02:58 PM
@chenjia1957 Voice calls are working and just not the data?
Was data ever work on your current phone?
What kind of phone is yours (brand and model)?
07-13-2021 02:56 PM
OMG......onslaught of info there tor you.
- Can you tell me the brand and model of your phone?
- Did you have data previously with pm?
- Do you have wifi?
07-13-2021 02:48 PM
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit HERE
click HERE
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
if you still not working you have to Submit a ticket to customer service by Moderator Team,
Only one way to solve your issue , explanation to customer service by Moderator Team
and the are nice service Team the will help you 100%.
Here’s how to contact customer service by Moderator Team,
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click HERE to get started.
- or you can send a private message to Moderator Team by Click HERE.
- You’ll need to be logged in to your Community account for the link to work.
- please include in your message,
- your account number, if you know it,
- your phone number,
- your account 4 digit pin,
- your Email address,
- explanation to them nice Team and nice service.
Good Luck
07-13-2021 02:47 PM
@chenjia1957 wrote:Hi,
Regards
Hello @chenjia1957 - 2 months!
Did you have data before then?
If so, check to make sure your Data Line is showing in your OVERVIEW tab in your Self Serve account.
If yes, try:
- rebooting your phone
- going into airplane mode then back to regular mode
- do a RESET of your Network Settings
If you never had data working, check your APN settings:
For Android = https://apn-canada.gishan.net/en
07-13-2021 02:46 PM - edited 07-13-2021 02:47 PM
Regards
Log in to your account and look at My Data and Add-ons. Do you see any mention of available data ? If not...that might mean you use it up.
07-13-2021 02:45 PM - edited 07-13-2021 02:46 PM
@chenjia1957 , support is via online only. You post questions in the community that do not require access to the self serve account. If you need the account looked into, use the chat symbol to initiate a support ticket. Anyway, does you self serve account show that you have unused data available. If there is, the next thing to investigate is whether mobile data has been turned on and if on, is there a usage limit that is blocking data usage. If that checks out, then check the APN settings to make sure they are correct. See links below for APN changes.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-iphone
