11-24-2016 12:21 AM - edited 01-05-2022 12:53 AM
11-24-2016 11:48 AM
Excellent, I've found the link that you're talking about here. I appreciate your response!
http://productioncommunity.publicmobile.ca/t5/Public-Lab/Self-Serve-Mobile-Site/idi-p/71855
11-24-2016 02:51 AM
Its under consideration. They are probably working on it...
11-24-2016 12:25 AM
There is an idea brought up in the public lab. The status of the idea is under consideration.
I hope it rolls out as well! 🙂
