3 hours ago - last edited 2 hours ago by computergeek541
I have a REALME 11 PRO+ with Android 13. I can make calls but my data doesn't work. I've changed the APN settings and also reset network settings. Data is on and wifi off, but in still offline. Any ideas?
2 hours ago
Thanks for the quick reply! Sucks if it doesn't work. I thought if u could send calls, everything would be OK. I'll try ur suggestions.
Thanks
3 hours ago
first, your Realme 11 PRO+ might not work very well on PM as your phone missed some important 4G bands used for PM. And I am not certain if you phone will work with PM's 5G at all since you missed the n66
your phone has the following bands (BOLD are compatible bands) :
4G bands 1, 3, 5, 8, 28, 38, 40, 41 - India
1, 3, 5, 7, 8, 28, 34, 38, 39, 40, 41 - China
5G band 1, 3, 5, 8, 28, 40, 41, 77, 78 SA/NSA - International
1, 5, 8, 28, 41, 77, 78 SA/NSA - China
these are the bands used for PM
With the lack of compatible bands, I would suggest you to use another phone on this network
But you can still try to update the APN profile and hope it works
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
