Mobile data isn't working
04-08-2022 09:11 PM
My mobile data is turned on, but it randomly decided to stop working. I tried restarting my phone, twice. I took my SD card out then put it back in, nothing. How can I get it to work again? My account is still active.
Plans
04-09-2022 10:50 AM
that happened to me too. not too sure why.
04-08-2022 10:52 PM
Your SD card??
Or your SIM card?
04-08-2022 10:48 PM - edited 04-08-2022 10:51 PM
@Pandalover Oh, you have a dual sim phone.
You should have a setting like this to tell the phone which sim slot to use for data, you can change the setting without physically changing the SIM:
04-08-2022 10:44 PM
I switched my SIM card to slot 2 instead of slot 1, now my data is working again. Not sure why I had to do that.
04-08-2022 10:25 PM - edited 04-08-2022 10:36 PM
@Pandalover wrote:3G, my phone is Samsung A02
@Pandalover why don't you try the LTE?
something like this:
04-08-2022 10:23 PM
@Pandalover - do you have the Global or North American version:
04-08-2022 10:18 PM
04-08-2022 10:14 PM
@Pandalover wrote:
this is how much I've used so far.
@Pandalover - you're right, lots, no issue there.
04-08-2022 10:13 PM
You need data or wifi for MMS, occasionally or very often? How long are your text messages normally...🙂
If iphone:
Try turning off iMessage and enabling SMS and MMS on our device.
If android:
Turn off your Chat Features if enabled on the device.
For your data issue try performing a Reset of your device's Network Settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
04-08-2022 10:08 PM
04-08-2022 10:02 PM
Hi @Pandalover This might be a faulty device or network problem in your area.
Have you try to put the PM SIM in another phone ? Try to use your phone in a different area, away from your home area.
04-08-2022 10:02 PM
Do you possibly have a vpn configured and on? I know this randomly stopped working but can you give images of your apn settings.
04-08-2022 09:57 PM
My data restarts every month, I don't use even close to the amount of data I have for my plan per month. I've barely even used 5MB for this month alone so far.
04-08-2022 09:53 PM
@Pandalover wrote:My mobile data is turned on, but it randomly decided to stop working. I tried restarting my phone, twice. I took my SD card out then put it back in, nothing. How can I get it to work again? My account is still active.
@Pandalover - do you have data left on your plan?
Check your overview section under this area. If the line exists then you do have data left. If you do not see any data line, then you have no data left to use in your current cycle.
04-08-2022 09:53 PM
Can you check your account for data under my data & add-ons? Or dial 611 and using your 4 digit pin check your data remaining.
04-08-2022 09:50 PM
@Pandalover can you check your phone Preferred Network? what is it using? LTE or 3G?
Also, what brand and model is your phone?
04-08-2022 09:49 PM
I tried turning off my WiFi and just have mobile data on. It's showing in my settings that it's on, but when I try to use the web it says there's no internet connection. So somehow my phone isn't even registering that my data is turned on.
04-08-2022 09:33 PM - edited 04-08-2022 09:38 PM
@Pandalover do you have the data issue when you are away from home?
If it is just an issue at home when you have BOTH wifi and Mobile data on, it could be an Wifi issue
When you use internet , phone usually will take Wifi as the data connection and not Mobile Data. When you have the interruption, it could be that the Wifi/home internet issue. Unless you have enabled Wifi-assist/Adaptive Wifi, phone will still stick with Wifi instead of Mobile data when both are enabled, even the Wifi is not returning proper internet.
04-08-2022 09:30 PM
I use WiFi and my data because I can't send messages without data on whenever it turns into an MMS.
04-08-2022 09:29 PM
I have my data on because whenever I write a long message it turns into an MMS. So I can't just use regular WiFi.
04-08-2022 09:26 PM
@Pandalover wrote:I am having the issue at home, I am on a 3G network. I have a Samsung A02.
@Pandalover You meant you have been using 3G ONLY? on the other hand, you tried LTE?
04-08-2022 09:22 PM
If you are at home. I would suggest you connect to your home wifi to reduce data usage.
04-08-2022 09:18 PM
04-08-2022 09:18 PM - edited 04-08-2022 09:20 PM
Try rebooting your phone and see if that helps. Power your phone off then back on.
Also try putting the SIM in another phone to see if it still shows the same issue to narrow down whether it is your phone or network.
04-08-2022 09:15 PM
@Pandalover did you get this issue at a specific location like home or work? or pretty much everywhere?
Try changing the network to 3G ONLY /WCDMA ONLY and see if it works better
What kind of phone is that? brand and model?
It could also be just a device problem. If possible, try to putting your SIM in another phone and use it for couple days and see if it is the same
04-08-2022 09:15 PM
*SIM card, not SD card
