01-23-2019 08:51 PM - edited 01-05-2022 03:08 AM
Hi,
I have a samsung note 8, when I turn on mobile hotspot the share my connection with my laptop, my laptop connects to the hotspot but with no internet connection.
Please help, Thanks.
Georges
01-23-2019 09:46 PM
@will13am wrote:
@computergeek541 wrote:
@georgesg wrote:Hi,
Georges
A while ago, there was an issue with one of Public Mobile's access points. When that happened, people just went ahead and used the other for hotspot purposes.
Georges, for you, it could be as simple as entering a setting of DUN.
I gave you a bravo anyway, but you need to be more concise on where to add dun. Please don't yell.
True that I didn't say where/how to do that. It was brought up earlier where that setting is/which setting to adjust on Android phones.
01-23-2019 09:42 PM
@georgesg wrote:Hi,
Georges
I gave you a bravo anyway, but you need to be more concise on where to add dun. Please don't yell. ![]()
01-23-2019 09:41 PM
@srlawren wrote:@georgesg what does your "APN Type" field show for sp.mb.com APN? It should be "default,supl,mms" with no spaces (and without the quotes).
On some android devices, the APN type field needs to have dun in addition to the items you mentioned. To this day, I have not found a reason why, just know that this is a solution that works. I have to use this solution when tethering from my Sony xperia z3 compact and nexus 7 2013 tablets.
01-23-2019 09:14 PM
@georgesg wrote:Hi,
Georges
01-23-2019 09:07 PM
When you have hotspot on does the internet work on your phone? Unless you have the 4G LTE then your data is being throttled and may be slow and time out on other devices when using it as a hotspot.
01-23-2019 09:00 PM
Here is the knowledge article on how to set up hotspot for phone:
Setting up a hotspot on an Android Device:
01-23-2019 08:57 PM
01-23-2019 08:57 PM
If data is working on your phone, then it's a phone issue and you must await an Android using member. Switch to iPhone and I can help. ![]()
