09-07-2023 10:24 AM
09-07-2023 10:55 AM
I added,, mms,, to my apntype
09-07-2023 10:41 AM
Can you get to web sites with your browser?
Have a look at your APN settings and compare to these.
Name: whatever you want
APN: sp.mb.com
MMS proxy: mmscproxy.mobility.ca
MMS port: 8799
APN type: default,mms,dun
APN enable/disable: APN enabled - probably on anyway and greyed out
MVNO type: GID
MVNO value: 4D
Save, then select to use, then go in and out of airplane mode
09-07-2023 10:35 AM
@Alex65 Well you can use this direct link to support to investigate for you
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-07-2023 10:34 AM
Already
09-07-2023 10:32 AM
Yes
09-07-2023 10:29 AM
Is the cellular data enabled in the Settings?
09-07-2023 10:29 AM
make sure data is enabled too.
09-07-2023 10:28 AM
@Alex65 Maybe try to reboot the phone or reset network settings see if that helps
