12-13-2023 08:24 AM
Hi everyone, how can I get the boat in message request again? Please help
12-13-2023 04:20 PM
please contact to the CS_Agent for porting in request, and then your previous provider will send another message to you. Or you can contact to your previous provider directly and request porting out!
12-13-2023 08:30 AM
@bhullarpr No worries I’ll send you the porting team number private message right away . Give them a call and they can re trigger the port request for you
12-13-2023 08:28 AM
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
