Missing calls altogether
luthien
I've been missing possibly up to 80% of incoming calls. What happens is this: someone calls me and it goes straight to voicemail. They'll leave a voicemail which I can listen to, but the call never appears in my call history. The only way I know they called is if they choose to leave a voicemail.
That means that if they do NOT leave a voicemail, I have no idea that they called, which is obviously a huge issue.
luthien
The suggestion to manually set to 3G seems to be working, although I have no idea why that should be the case. Thank you!
@luthien
Try rebooting your phone by powering it off wait couple of minutes then power back on.
If that didn’t work, it could be a backend provisional issue. Contact a CS_Agent to look into it for you.
Meow
One of the reasons could be your signal is very low so system thinks your phone is off and then it redirects call to vmail.
luthien
Thanks, I'll give that a try. Hopefully it helps.
RossN
@luthien hi go into network settings and manualy set to 3g see if that helps with your calls
