Minutes
Bear2
If I run out of in plan minutes will I still be able to receive incoming call and text?
8 REPLIES 8
treefrog
@softech
It only took nine months that was almost as  hard as having a baby!
@treefrog wrote:
Woo-hoo! Wow thanks my first solution!
First one is the hardest.. now, they will come pouring in  🙂
Have fun!!
treefrog
@treefrog wrote:
@Bear2
Unless you have the old  $10 50/50 plan or the briefly offered original $15 plan offered in the spring of 2019 then you have unlimited incoming calls and texts. As suggested the $5/500 minutes add on is an excellent value for this plan. You should consider getting a calling and texting app like Fongo or TextNow to make free calls and texts while on Wi-Fi or mobile data. You can use these apps for calling your voicemail so you don't use up your 100 outgoing minutes calling your voicemail.
There are also people who could have a $15 plan that does not included unlimited incoming, and other who could have plans that that do not have either calls or text messages.
@Bear2
Unless members know the exact plan that you have, your question cannot be accurately answered.
HALIMACS
Yes!!!
treefrog
@Bear2
Yes. Look at buying the $5 500 Minute Canada Wide Add-ON. It does not expire till all minutes are used up. Carries over month to month. Cheap insurance to cover you once your 100 have been used up.
RosieR
Hi @Bear2 yes, all plans have unlimited incoming calls and unlimited text and picture messaging.
Stay safe
RosieR
