Mifi
CRW
Does Publicmobile.ca have a Mifi data plan?
1 REPLY 1
JRod
@CRW
Public Mobile does not have any plans specific to Portable Hotspot devices.
But if the portable hotspot supports nano-sim you might be able to pick a plan here and put the nano-sim in the portable hotspot to get it to work the way your intending. If you’re already a customer and have a physical SIM card you could try this out and report back.
