Mexico
Jo444
Hi there
I am heading off to Mexico in a couple of days. I have the Canada/USA/Mexico plan. My question is….do I just make sure my phone is set for roaming and carry on as usual in terms of phone calls, texts and data usage?Seems too easy. 🥴
2 REPLIES 2
hi @Jo444
yes, just make sure Roaming data is toggled on, the phone should connect to AT&T or Telcel, or you can manually connect to them if not
and you might still receive a text asking you to buy roaming, just ignore it, it is a text that sends to everyone.  Most important thing, Enjoy the trip
