01-15-2026 11:00 AM
Hi I got a LG 5g velvet lost Voice service this phone is VOLTE compatible, I tried the sim card is my friends s24 and voice service work put back in my LG no Voice service at all data texting works though????
01-16-2026 01:02 PM
hi @durnfordb
Try Reboot phone and click Reset Network settings
if same, submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
01-16-2026 01:00 PM
same issue here with VoLTE on a LTE tower. Phone is compatiable according to their checker. I phone 15. This happens in this location quite frequently with other phones and providers and sometimes needs provider intervention
01-15-2026 11:33 AM
You were always using 3G for voice. But Manitoba is the first province to have 3G network shutdown.
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
you need a phone that is compatible with PM's VoLTE network, but unfortunately, your LG phone is not compatible and you need a newer phone, like Samsung S22 and above, A35 or so
01-15-2026 11:14 AM
I see but It always worked before on VOLTE on the 1900MHZ band in Souris Manitoba witch is off of a Bell tower as Telus only has towers in Winnipeg and Brandon Manitoba.
01-15-2026 11:06 AM
LG Velvet is VoLTE but it is not a phone that is on PM's VoLTE whitelist. You can confirm that using the IMEI checker here:
https://www.publicmobile.ca/en/get-help/articles/volte
Telus is currently refarming the 850MHz band 5 spectrum and hence you are left with 1900MHz for voice calls.
Since this phone's VoLTE does not work with PM system, there is really nothing much you can do other than getting a phone that is on PM's own VoLTE whitelist.
