Mexico calling
Dustin4
Can I receive phone calls while in mexico?
HI @Dustin4
they just come out with roaming in Mexico, please check
https://www.publicmobile.ca/en/on/plans?network=BLACKFRIDAY
we still don't see roaming addon in Mexico yet.  So, if you need to get connected in Mexico, getting the Canada-US-Mexico plans is the only way
DennyCrane
Public Mobile does not have any roaming service in Mexico. If you want to receive calls on your Public Mobile number while in Mexico, you'll need to set up call forwarding (while you're still in Canada) to another number that you can access while you're in Mexico. A suggestion would be to get a free Canadian number from TextNow or Fongo, and forward you Public Mobile number to that. Then get a travel esim or local sim for data or just rely on free Wi-Fi to access calling features via the TextNow or Fongo apps.
@Dustin4  Sorry PM only has roaming in the US , for Mexico your best to bet travel sim like airalo or buy local pre paid sim in Mexico for your trip
sorry @Dustin4 you cant.  No roaming for Mexico
woekaoriis to use to VOIP app like TextNow and use the number it assigna you
Dustin4
But if I buy a local sim I would have a different number so wouldn’t be able to receive calls from my actual number then or is that possible somehow
Sansan
@Dustin4  no you cannot. You would need to get a local SIM or connect through wifi where available.
