08-24-2025 12:05 PM
Switched to PM on Friday with a new iPhone 15 and e sim and cannot receive or send messages. What could be wrong?
08-25-2025 09:16 AM
Deleted the eSIM. Did a master restart. Added new eSIM and still nothing.
08-24-2025 08:21 PM
I did press Yes within the time frame. Thank you for the number.
08-24-2025 08:18 PM
Your post was not completed
Did you get a porting authorization text from your old provider? You need to reply them YES within 90 minutes to approve the port
there is a porting assistance team you can call and ask for update or fix the port. I can't post the number here, but I will message the number to your community inbox. Please check and call them
08-24-2025 07:32 PM
I am not getting incoming calls. I can call out.
08-24-2025 06:34 PM
Can you check to confirm if you can get incoming calls? If you are porting your number, I am not sure if the port was completed. If not, then you will have to wait till it is and try re-register
08-24-2025 06:29 PM
I opened a ticket, thank you!
I tried to register but receive an error message and cannot log in with my apple account since I cannot verify it through text.
08-24-2025 03:47 PM - edited 08-24-2025 03:48 PM
Check id your iMessage is properly registered (might need to re-register). And check if Send Text Message is enabled
If you need PM, you can open ticket with them. Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
08-24-2025 03:43 PM
New phone. Only installed the eSIM. No regular sim. Did network reset and reboot. Still no messages
08-24-2025 12:42 PM
make sure all the old esim is disabled
And make sure the PM esim is the only one there and enabled. Then Reset Network Settings
08-24-2025 12:33 PM
Purchased a new eSIM
08-24-2025 12:30 PM
Did you remove your previous carrier's SIM card? Or inactivate/delete old carrier eSIM?
08-24-2025 12:24 PM
Thank you for the advice. Reset and rebooted. Still no change. The phone does not turn iMessage on (I receive an error code when trying to move the toggle). Spoke to apple. Twice. They think it is a network operator issue.
08-24-2025 12:16 PM - edited 08-24-2025 12:17 PM
@Gal424 wrote:Correct. Received the text. Replied. Calls work. Neither regular nor iMessages work.
OK. Try this. Go into Settings and reset your network settings. Then reboot. This should help.
Settings, General, Transfer or Reset iPhone, Reset, Reset Network Settings
08-24-2025 12:15 PM
08-24-2025 12:13 PM
@Gal424 wrote:Switched to PM on Friday with a new iPhone 15 and e sim and cannot receive or send messages. What could be wrong?
Now when you say "switched" do you mean you ported your number from another service provider?
