Messages of outlook on device
avabarker
I have a problem. I can't get data from some my messages in Outlook. I store it on my phone, I can't open it, but other messages are easily opened. I don't know what to apply...
9 REPLIES 9
matbasm
Not sure if you have thought of, or might be interested,  but BlackBerry Hub is available on Android. Can also get BB contacts app.
mimmo
Was hoping more of a sync solution vs import export.  Will do some testing when I get home.
@mimmowrote:
@NDesai thanks for the feedback.  It's not the first time I have heard outlook is better.
Going to try it out.
Also do you know if it is possible to sync Gmail contacts with outlook(Android) and then outlook for PC.
Haven't tried but i am sure you probably can export and import.
mimmo
@mimmowrote:
@NDesai I have the outlook app installed(Android) why do you feel it  is better than Gmail?  Thinking of trying it out.
For a single account, Gmail is fine. But i have about 3-4 emails including work email that are added into the same app. The interface and design is much better than any other email apps. Many times with Gmail app, i stop getting notifications and when i open the app, it starts loading for a few seconds to load new emails. And the layout including the fonts and colors are just not my type. So just small things like that annoys me, and that is why i think outlook outperforms other apps.
EDIT: Forgot to mention that Outlook allows you to set separate notification settings for each email account you have added.
mimmo
DomRiley
You need to do following. You may do it by two ways.
Google is your friend on phrase fix .pst, I found numerous variants for you, just see.
Second variant might be innovative thing that is called Outlook Online Service, it supports upload any sizes of files and most popular OS like Windows, iOS, Android, whatever you like or have.
I love the Outlook app. IMOH it beats out all email apps. I never had any issues with it. If i feel something isn't right, i just reset the account from settings. For you problem, it looks like some of your emails are not loading probably due to their contents. Are you able to open those emails on wifi?
BTW, emails are never stored on a local device. Attachments you download from emails are stored locally on your phone.
srlawren
@avabarker you might have better luck in an Outlook support forum [edit: example--Outlook for iOS and Android Support Center] or something--this proably has nothing to do with Public Mobile.  With that said, maybe someone here can help.
Are you using Outlook on Android or iOS?  Do you have the most recent version available from the Play Store (Android) or App Store (iOS)?  You say you can't open certain messages--what happens when you try?  Do you get an error message of some kind?  If so, what does it say?  Did this just start happening recently?  The messages you can't open now, were you able to open at least some of them in the past?
