Message send failure
QIANLI
I changed my number today, from Ontario number to a local Calgary number. And then I cannot send text. Keep showing message send failure.
restarted my iPhone. Turned flight modal off and on.
checked setting-message, iMessage is available for the new number and Apple ID.
can still use data and call. Just message failed. @CS_Agent
@QIANLI
Your Apple ID probably still have your old number so go to Settings>your name on top of the page>Name, Phone Numbers> Email>Contactable At>Edit>Add a Phone Number… reboot your phone and you are done!
HI @QIANLI
you cannot send text or iMessage?
you should try to remove the phone number from iMessage/Facetime, reboot, then add the number back and try agian
Chalupa_Batman
Hi @QIANLI
If you have an iphone try this. Go into Settings, Cellular, Network Settings, turn off automatic and choose Public Mobile. Then reboot. Let us know if that worked.
@QIANLI  Maybe try resetting network settings . Is it possible for you to try the SIM card another  phone to test .and make sure airplane mode is off
