12-10-2022 01:37 PM
12-10-2022 05:45 PM
@Marycastro If/when you contact customer support for login issues, you may also want to ask them to change your username as well if that's your real name you're using for the Community account.
12-10-2022 01:44 PM
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-10-2022 01:41 PM
hi @Marycastro what error you got? tried Reset Password?
or open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
12-10-2022 01:40 PM
What are you needing to do?
Try using private mode or a different browser or even device. Often a non-mobile browser works better.
Were you able to use the password reset? Are your services working? Do you have the sim in a phone?
