03-03-2021 03:45 AM - edited 01-05-2022 05:28 PM
Howdy,
Just wondering how to mark post as solved, and how to flash the appropriate comment.
Thanks!
03-13-2021 12:03 AM
... or don't.
It might remain an Unsolved Mystery forevermore. Which I personally think is more exciting and adventurous, to be honest.
Or it might get Solved whenever @Luddite gets around to it during his housekeeping rounds, lol.
03-03-2021 08:27 AM - edited 03-03-2021 08:45 AM
@DarianDNewell wrote:Howdy,
Thanks!
Like this, @DarianDNewell . Bravo someone on left, Accept as Solution on right. Only the original author sees the "Accept as Solution" option on posts within the thread they started.
The Oracles can assign solutions which best fit the initial inquiry or remain unassigned.
Remember, it's frowned upon to mark one's own reply post within a thread as a solution. Just don't do it unless it's really the best solution to the problem and you've found it independently of feedback that others have provided.
03-03-2021 06:50 AM
Thanks!
When you start a thread you will have the option to select which response best helped you based on your original question.
If you choose one by mistake, you also have an option to change it.
Note, some oracle will selection Solutions after so long, if one was not chosen. This helps others when they have similar issues and come searching for answers on the Community.
If you want to tag someone use the "@" symbol in front of their name, and they will be notified you are mentioning them.
Welcome and See you Around!
03-03-2021 04:36 AM
Thanks!
The option shows on replies in a thread. It's given to the person who answers the quetsion.
